I just watched this video. I never saw it before. It's pretty good. I watched it at 2X because at 1X it is annoyingly slow.
https://www.youtube.com/watch?v=MGt8cnVIKW8
There are dozens of variations on how to do this that you will likely think of. I usually have an ideal "cold temp" and for PLA that's around 95C. For Nylon and ABS it is closer to 110C. Nylon is really a fantastic cleaning material but you can do it with any filament. Joel's method in the video of warming while pulling works and I do that also but I start at a higher temp than he does. You can also twist as you pull. In that case you can go much lower temperature and for PLA even room temperature. Most people don't twist. It works fine either way.
gr5 2,210
This is a complicated topic. I would try using a different core. Your printer should have come with two "AA 0.4" and one "BB 0.4" core. Assuming you are using one of the AA 0.4 cores, try using the other.
If this fixes your issues then it could be a faulty core or you just might have to clean the nozzle. "curling" out of the nozzle is a sign that there might be some caramelized filament inside the very tip of the nozzle.
Clean the nozzle with many cold pulls. There is a menu item on the printer, probably under "maintenance" that walks you through the process.
I do cold pulls manually (I remove the bowden, change the temperature manually). To do it manually google "3d printing nozzle cold pull" and watch a video (can be any printer type -doesn't have to be an ultimaker).
