Missing settings
Lukasarn
Go to solution Solved by GregValiant,
Posted · Missing settings
Greetings to all,
I have a little problem with my walls. As you can see in the picture, the I point is not completely filled. I know it's because of the width of the dot, but with a font it's difficult to set a multiple of the nozzle diameter exactly. I've already found a few posts where the problem is addressed, but I can't find the setting that is supposed to solve the problem. The option should be called "Fill gaps between walls". Unfortunately I can't find this. I downloaded the latest Cura version yesterday. All posts were published during an older version. Does the setting still exist? If so, how do I find them? Is there another solution or another setting?
    • Solution
    The "Fill gaps between walls" setting is gone.  The "variable line width" of 5.x versions replaced it.
    In the Wall Settings section of Cura are new settings to adjust this.  Try lowering your "Minimum Line Width".  The default for a 0.4 line width is 0.34 so try making that 0.30.  There are other settings too play with as well.
    • Thanks 1
