We are further investigating this problem. Printing with two colors, meaning a part color A and a part color B of the same object is no problem. But mixing e.g Yellow and Red to get a type of Orange has a strange effect when I print a cylinder. One part of the circle is Yellow slowly changing into Red and then back to yellow when tthe circle is closed. And that happens then again for the next layer again.
Our, hcc!3D, has as first conclusion that the colors are not mixed but going not mixed through the 0.4 nozzle. Why? because the inside of the cylinder has the color change in just the opposite direction. So when the outside is Yellow, the inside is Red. The nozzle is making a circle but has relative fixed position, which explains that the inside and outside have opposite colors. We are still further testing. I will close this question when we close our investigation to prove that we are right.
MariMakes 192
Hey @BVD,
Welcome to the Ultimaker Community 🎉
There is this amazing research about 3D hatching.
You can read more about it here:
https://ultimaker.com/learn/3d-hatching-grayscale-printing-on-the-ultimaker-3
And participate in the discussion with the creator BagelOrb here:
There is also the Mosaic Palette which you can use for multicolor.
https://www.mosaicmfg.com/blogs/news/ultimaker-3d-printers-and-palette-2-2-pro-now-compatible
That's the ways that I know how.
