Im using cura ant prusa slicer but dont use any z offset settings on it.
The number of z offset are same but nozzle push plate hard after print. Sometimes even after setting z offset with paper everything ok, i press home and try check one more time and wrong.
GregValiant 1,330
The Z-offset is typically a printer firmware thing. Are you using a plugin in Cura to set the Z-Offset? Maybe there is something in your startup gcode that affects it?
Is the actual number value of the Z-offset changing or is the printer simply doing something different (even though the number is the same)?
