3 hours ago, GregValiant said:The red edges on the walls indicate that there are errors in the model. (Looks like the normals are flipped upside down).
If you repair the model it will slice as expected. Right now the errors are confusing the Cura slicing engine as it can't tell the inside from the outside.
I have no idea what size it should be but I repaired it in MS 3D Builder. Make sure you have "Remove All Holes" disabled as well.
You were right on the money. I recalculated my normals in Blender and now it slices perfectly! Thank you!
GregValiant 1,330
