Hi @GregValiant
Firstly, thanks so much for taking the time to help.
Quote
- You can try going to 4 walls and 0% infill.
I actually did set it to 99 walls prior to printing... typical for lithophanes. I guess I reverted that prior to saving the settings I uploaded.
Quote
- You have "Max comb distance with no retract" set to 30mm. Drop that to 3mm to force more retractions. That should allow you to turn off "Retract before outer wall".
Thanks. I'll give that a shot
Quote
- I see you have the retraction distance set to 2.0mm. You have a direct drive on your printer?
Correct
Quote
- The setting "Avoid printed parts when traveling" tells Cura to compute the travel moves off the part. I think you would be better off with as many combing moves as possible within the part.
I wondered about that. I tried with and without and it seemed to make no difference.
Quote
- In Travel - set the Layer Start X and Layer Start Y to the same numbers as your Z seam location.
That's something I hadn't thought of! I'll give that a shot as well.
QuoteI see you have a lot of Flow settings at 85%. Is there a reason you need to under-extrude by so much? Single wall calibration cube perhaps? This is not a single wall print.
Ok, so extrusion is something I've only recently bothered trying to calibrate, and yes I was going by a single wall calibration cube as per... well... just about all the tutorials out there! Of course this is not a single wall print, but surely the calibration universally advised isn't just for single-wall printing, right? I do have to say, I've had much more accurate printing results since changing to the lower figure. 85% is actually one of my higher ones. Most of my rolls calibrated out to 82 to 83.5%. With that said though, I have noticed some under-extruding issues, and this model was a prime example, in that there are little pin holes in the thinner areas that shouldn't be there.
Do you have a tip on best practices if you don't think I'm doing it right?
Thanks!
GregValiant 1,119
Hello @bcsteeve. I took a look and yeah, there is a lot of travel for such a small print.
One of the problems I see is the geometry of the model itself. The Inner Walls stop and go so there is going to be travel between the areas where there is Inner Wall to print. The Infill only exists on the ends and Cura prints Infill separately so there is travel from one end to the other to complete the infill on each layer.
With your current settings there are about 2040 retractions in the gcode. Making the changes above there are about 8000 retractions. Almost all of those additional retractions are before travel moves and that should seriously cut down the amount of strings you are getting.
