No, the problem is also present in other models
GregValiant 1,330
If those settings are turned off then use the "File | Save Project" command and post the 3mf file here. Someone will take a look.
Looking into the rectangular holes in your 2nd and 3rd images it looks like "Make Overhangs Printable" might be on.
Hey @ToB,
Welcome to the Ultimaker Community 🎉
I tend to agree with @GregValiant, I believe it's one of those settings that are affecting your printjob.
Do you have a project file for us? It contains the printer and settings we need for troubleshooting.
To save a project file go to File -> Save project.
I had the "Make Overhang Printable" setting on and overlooked it🤦♂️. Thanks for the help 🙂
GregValiant 1,330
It could be a model error but the easy check is to make sure you have Mesh Fixes "Remove all Holes" turned off and in Experimental make sure "Make Overhangs Printable" is turned off.
