1) That would be a lot of work - you would have to be reasonably good with linux and see if it already has the USB/ethernet driver and if not download it and install it using wget or similar linux utility and then set it up with conman which is all doable if you are good with linux and you would also lose all of that work each time you upgraded the firmware.
Instead maybe get something more like this:
https://www.amazon.com/IOGEAR-Ethernet-2-WiFi-Universal-Wireless-GWU637/dp/B018YPWORE/
2) Regarding active leveling - there are known issues and known fixes. What is the number that displays when you do the leveling sensor check? <8 is good. 3 is more typical for a good printer. The fixes usually involve replacing the side fans as they have coils and I'm guessing they act as antennas. You can unplug them to prove it is fan related but unplugging involves taking apart the head so not trivial. Since you have had trouble since the beginning you should be able to get replacement fans for free - or whatever service is necessary. Typically they replace the leveling sensor which is never the issue, then the board in the print head, then the cabling and finally the fans which is usually the issue (I think - not an expert).
3) What are these other issues about first or second try? Is this also active leveling or something different?
APL-3Dprinter 0
I wonder if this adapter would work... https://www.amazon.com/Moyina-Gigabit-ethernet-Network-Chromebook/dp/B0829X2LTY/ref=sr_1_10?crid=1O9K33QEZ7YAQ&keywords=usb+type+a+to+rj45&qid=1671034693&sprefix=usb+type+a+torj45%2Caps%2C97&sr=8-10
