Posted
· Open face getting filled in - Help Please
Go down to the Experimental section and turn off "Make Overhangs Printable". It's a specialty setting and is handy when it's needed, but that isn't often. (It adds chamfers to your model features so they don't require support. That is often not what the user wants.)
Another one to watch out for is "Remove All Holes". It is now linked to Spiralize Outer Contour" and if the link gets broken it will stay on when Spiralize is turned off and cause the same sort of behavior you are getting here.
GregValiant 1,303
