Standarteinstellung Ultimaker Cura 5.2.1
Mbinguel
Posted (edited) · Standarteinstellung Ultimaker Cura 5.2.1
Hallo,
kann mir jemand bei der Einstellung (Werte) helfen?
Die Düse ist nach ca. 20 Minuten Verstopft!!😳
Drucker
Creality Ender 3
Extruder
Creality Sprite Pro
Düse
Messing 0,4 mm
Filament
PLA 1,75mm
Temp
210 Düse
60 Bett
Slicer
Start g-Code:
; Ender 3 Custom Start G-code
G92 E0 ; Reset Extruder
G28 ; Home all axes
G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish
End g-Code:
G91 ;Relative positioning
G1 E-2 F2700 ;Retract a bit
G1 E-2 Z0.2 F2400 ;Retract and raise Z
G1 X5 Y5 F3000 ;Wipe out
G1 Z10 ;Raise Z more
G90 ;Absolute positioning
G1 X0 Y{machine_depth} ;Present print
M106 S0 ;Turn-off fan
M104 S0 ;Turn-off hotend
M140 S0 ;Turn-off bed
M84 X Y E ;Disable all steppers but Z
Extruder Start g-Code:
M92 E424.9
M500
Edited by Mbinguel
    • Mbinguel changed the title to Standarteinstellung Ultimaker Cura 5.2.1
