Before you change your Printer Definitions there is something else you can try.
There are a number of settings that influence your build volume.
You can change this for your specific printjob without influencing any of your future printjobs by permantly changing your configuration!
Build plate adhesion, You can reduce the brim size, or set the adhesion type to None to get a lot of space back
Travel avoid distance, is you reduce this to 0 you should also get some space back but the nozzle might leave some residu on your print
Support horizontal expansion, if you have support enabled horizontal expansion helps with printing on top of the support but influences the space you have to print
MariMakes 204
Hey @Deepblue12,
Welcome to the Ultimaker Community 🎉
You can read more about them here.
https://support.makerbot.com/s/article/1667337565436
