Ability to define the Gray Area on the build plate.
choppman42
Posted (edited) · Ability to define the Gray Area on the build plate.
Please give us a way to change the gray area on the build plate in the machine settings.
This is the way I used to be able to fix the issue.
https://www.youtube.com/watch?v=Il1sierB4Yk
after doing some googling..
I found a different videos that shows it is a hidden value inside the skirt. This videos shows how it can be changed, but if i don't use a "skirt" this value still affects the build plate and to me it is hidden and could be a frustration to many people to want to use all the build plate, but can't due to this value for the skirt.
https://www.youtube.com/watch?v=up4sInRgjes&t=28s
Could you be set in the machine settings instead?
Edited by choppman42
    Posted · Ability to define the Gray Area on the build plate.
    The method in that video still works, though the exact path of the file has changed a little. It is also still a very easy workaround to tell Cura you have an Ender 3 Pro instead of an Ender.
    But most importantly, you should realize the gray areas are there for a reason. Please read this article about the different types of gray area, and how they are affected by things like a skirt or brim etc:
    https://support.makerbot.com/s/article/1667337565436
    • Like 2
    • 2 weeks later...
