Walls have gaps in Cura 5.2.1
Go to solution Solved by neute,
Posted · Walls have gaps in Cura 5.2.1
Hello,
Im new to 3D-Printing and i am currrently using the cura 5.2.1 slicer. But the part I'm working on contains gaps at the end of certain layers (inner and outer walls). I started playing with some settings but i have no clue how to fix this issue.
Thank you for your help!
    • Solution
    @Noppi do you have coasting enabled? It stops extrusion a bit before the actual end of a line to release pressure in the nozzle, this is mostly relevant for bowden extruders to prevent stringing. It shows in the GCode just like it does in your screenshot.
