GregValiant 1,351
You can if you want. As you noted - the problem was fixed without changing anything in the program so is it a bug?
Yes, rather have the product manger focus on more important issues.....Log File in my personal data
banks when if it happens again.....
GregValiant 1,351
Maybe it's just a "Setting Visibility" thing.
Next to the "Search Settings" box is an icon with three lines on it (you can see it in your screenshot). That is the Setting Visibility tool. Click on it and set the visibility to "All" and see if the rest of the settings show up.
ahoeben 1,986
Or "Expert" instead of "All".
"All" will get you many settings that you likely will not be using, and that will make the long list of setting "unwieldy" and sometimes just confusing.
RogueWave 15
Somehow "Profile" Search Setting changed.....Expert is a "Expert"
Just refreshing different settings solved the Problem.....THANK YOU
Should a bug report be generated?
