Hi Nallath,
thanks for your reply. First, sorry for yet another post of a user venting frustration about things they don't understand, I see those quite often around here.
On 1/6/2023 at 4:42 PM, nallath said:What is probably going on is that the igildur quality profiles set the shrinkage percentage. Alternatively it could also be that they are influenced by what the other extruders are doing. Some settings need a single value for all extruders, even though materials can influence it (material shrinkage is one of them).
I think the latter is the issue here. There are no qualities for these specific iglidur materials, since I've created them from scratch with new GUIDs and everything. I've played around a little with loading different materials between the 4 extruders and disabling single extruders and I do now understand more or less how it behaves, as well as understanding the formula that calculates the average shrinkage between the active extruders. I just need to remember that I have to check on this setting if I'm using more than one material or have more than one extruder active at a time (which the whole intention of creating material and printer profiles in the first place was to not have to go through the whole settings pane before every print job)
How do I know if a setting is shared between extruders, is it just the "settable per extruder" parameter?
Re my question "am I doing this right" - where should the setting "material shrinkage" be included for a material; it seems that it is not intended to be in the material XML. Should it be in a quality profile even if it's theoretically the same over all hypothetical qualities? Intuitively I'd want it to set only once/in a single place in this case.
thanks again, have a nice week
Best, Niklas
nallath 1,125
Because the things we store are keys and the things you see are labels. We can't store the labels, as they can also be translated.
For the rest, you might want to check https://github.com/Ultimaker/Cura/wiki/Profiles-&-Settings
This is far from stupid, but a legacy thing. In the Ultimaker profiles, these are also no longer used. The reason for this being the default reason is that it was orders of magnitude faster to slice a few years ago. Generally speaking, we are quite conservative when it comes to changing settings for pritners that we don't have (as we are unable to test them).
