Fan Speed Help Requested, material is ABS
Dana1960
Go to solution Solved by GregValiant,
Posted (edited) · Fan Speed Help Requested, material is ABS
I'm printing ABS in an enclosed 3D Printer. The attached models are the entire part and a segment of the entire part. The segment prints out very well. The entire part does not, see image. The issue is cooling and the print starts deforming around layer 50 and continues to ~ layer 75. Comparing Gcode results in a stark difference in cooling for those layers. The small part has 66% cooling whereas the full part has 15-30% cooling for those layers.
ABS cooling must be used wisely, or the part will be brittle and or warp off the bed.
Attached are the project files. Not sure this will be useful given the printer type is QIDI. So also attached is the GCode files & files containing the M106, M107, & Layer values in txt format, Duct Gcode.zip
I think I need to dick around with cooling settings, see cooling image. Please suggest possible strategies to resolve this issue.
What I would really like is a way to paint on cooling values for areas of a print that builds up too much heat. ABS may find this quite useful. Also, a way to see the fan speed in the slicer preview would also be useful.
1768022040_MonoDuctComposite-Body.stl Mono Duct Segment.stl 1727174379_XMAX_MonoDuctBodySegment.3mf 387699720_XMAX_MonoDuctComposite-Body.3mf Duct Gcode.zip
Edited by Dana1960
    Posted · Fan Speed Help Requested, material is ABS
    You need to increase the regular fan speed, otherwise it will stay at the minimum speed you have set at 15%.
    the print will start at the minimum value and ramp up to the regular speed at the set regular speed layer(which is layer 4)
    in your settings.
    I increased the maximum/regular fan speed threshold from 25 to 50 seconds and looked at the cooling values in Gcode. Much better results, but not perfect. I'll try the minimum fan speed as well.
    • Solution
    @Dana1960 I'm an amateur hack and write a bit of code.  One of the things I thought Cura lacked is the ability to create a "profile" for fan speeds.
    Included with this little Windows app is a Cooling Profile generator.  You can change fan speeds at any layer, shut it off, turn it back on...whatever.  There is also an option to adjust the fan speed according to Line Type (Wall-Outer, Infill, Support Interface, etc.).
    Greg's SD Print Tool
    This is the "By Layer Number" page:
    This is the "By Feature Type" page:
    The app opens an existing Gcode file created with Cura.  You set up your fan profile.  The app then creates a new gcode file and writes the original into it with the fan profile inserted.  You end up with the un-altered original file and a new "Cooled" file.  (The M106 lines are PWM so all the percentages are translated to 0-255 scale.)
    If you decide to install it a shortcut will be added to your desktop and there is an un-install app.
    If you decide to try it and come across any issues let me know.
    Edited by GregValiant
    @obewan, I tried using the minimum fan speed. It helped somewhat. However, it doesn't solve the various cooling requirements for the overall model. It solved most of the problem. Now it fails above the raft. This is due to it is considered a skin thereby using the regular fan speed value and then increases fan speed gradually from there on up resulting in dropping for few layers. I'm going to give the above tool a go.
    Honestly, trying to resolve these types of issues with esoteric settings makes for many trials and is therefore very time consuming. When in fact a more direct approach, as in the tool above, makes for a greater understanding. Perhaps it too will be time consuming but educational.
    "Perhaps it too will be time consuming but educational."
    That is 3D printing in a nutshell.
    Every day I strive to learn something new (good for the mind) and do a good deed (good for the soul).
    @GregValiant, your latest tool version works great. I examined the file contents, all is well.
    Greg, When I open your tool to use on my Magician x I get an error
    "The port is closed".
    Do you hae any suggestions on how I can me open the port?
    THanks, Cant wait to try your tool!
    Enter
    Where did you copy the file to?
    Are you adding it as a post-processor in Cura?  (Extensions/Post Processing/Modify Gcode and then "Add Script".)
        • 6 replies
