Um2+ main board aging: adding a fan to cool the board ?
I have been using this output (24 VDC) since 2016 for two 12 VDC fans, connected in serial for cooling the main PCB that have been working perfectly all the time and still do.
Number one problem for the electronics is the "overheat" that is killing the semiconductors, number two problem -is the humidity!
Those two fans have cooled the whole upper part of the main board. There is no brownish colored stepper driver circuits and the board look as new after seven year..
So, go and use it, this is your best ensourement! Just use it!
This is a direct 24 VDC when power switch is turned on.
Torgeir 250
Hi @Coyote_Blue,
Sure I can.
Thanks
Torgeir
Edited by TorgeirEdited text.
Coyote_Blue 2
Hi Torgeir
I shall try it asap. Many thanks for the quick reply
