- Solution
Actually, I'm using Octoprint, so I'm going directly from my PC to Octoprint, and not writing to an SD card. Using Cura 4.8.0, there's not a problem, so it's not the file system. After clearing my head this morning, I went back into 15.04.6 to see if anything in the settings might have changed that could be causing the problem, and I found it. Somehow, the number of extruders had changed from 1 to 5! I reset it to 1 and checked it out, and that was the problem. Duh! Thanks for your help!
Edited by randywhartonFound solution.
ahoeben 1,981
It would be my guess that the gcode file is not getting written to your sd card correctly. Try formatting the SD-card, and then try again.
Having said that, Cura 15.04.6 is at least 7 years old. Old software sometimes stops working reliably. Maybe it is just time to update.
Edited by ahoebenLink to post
