oh, i didn't see the answer..
MeshTools are installed and active already - body is not watertight is the only message but that may be fine as the model is open at the bottom
Fast-Quadric-Mesh-Simplification is unable to load my STL - tried binary and ascii mode
I can send you model and project, is there another way to upload as I don't like to publish the full model?
since I needed to change support to 'everywhere' also a part of the model get's supported that should not get supported and the support-blocker get's ignored
same model works fine in Cura 4.8 in both cases
MariMakes 201
Hey @herzla,
We often see this error if the mesh is faulty
Have you tried doing a quick mesh fix with the Meshtools Plugin?
You can get it here: https://marketplace.ultimaker.com/app/cura/plugins/fieldofview/MeshTools
If that doesn't fix it you can try a more elaborate mesh fixer like https://myminifactory.github.io/Fast-Quadric-Mesh-Simplification/.
Do you have a project file for us? It contains the printer and settings we need for troubleshooting.
To save a project file go to File -> Save project.
