G10/G11 codes not generated when firmware retraction is enabled
Go to solution Solved by jhelmstetterjr,
Posted · G10/G11 codes not generated when firmware retraction is enabled
I have a CoreXY printer using a Duet3D Wifi. I enabled firmware retraction in Cura 5.2.1, but when I slice, the gcode generated does not have any G10/G11 codes present. I found an earlier post about this but I do not believe this is the same issue. Am I missing something?
