HDD Crash Need old Profiles Imported
123mash123
Posted · HDD Crash Need old Profiles Imported
Old HDD crashed, had to reload Windows from scratch. Was able to not loose any data, just the ability to boot from the damn thing. So... Cura 5.2 is re-installed, I have my old profiles on the old HDD but need to import them. All the files in the C:\user\xxxx\appdata\roaming\cura\5.2\quality_changes are available to import to the newly installed Cura, but I can't figure out how. I tried to cheat and just move them over to the new HDD and Cura doesn't see them. So.... I have about 30 profiles I don't want to re-do. all the profiles end in       .inst.cfg
    Have you tried copying over the entire C:\user\xxxx\appdata\roaming\cura\5.2 folder? That should get you the whole configuration you had on the old installation.
