My Printer changes direction
doubird1
Posted · My Printer changes direction
I use cura with my Duplicator Mini i3. Most of my prints, i use a brim.  Bed adhesion is ok.  The problem i noticed is that when the brim is done, the printer changes direction to print and often leaves either a blob or a small line of filament that after gets in the way. Is there a way to fix this? Is it a Cura settings problem? Thanks for any help.
    Hey @doubird1,
    Do you have a picture of your problem, and a  project file for us? It contains the printer and settings we need for troubleshooting.  To save a project file go to File -> Save project.
    I think your issue might be solvable with the correct combing and retraction settings.
    Or you could be running into an issue similar to this one:
    • 4 weeks later...
    On 1/30/2023 at 7:56 AM, MariMakes said:
    Hey @doubird1,
    i saved the project and uploaded. hope it helps to understand.
    barMount.gcode barMount.3mf
