On 2/6/2023 at 12:15 AM, ahoeben said:It should still be possible to load the *.ini file as a profile using the "Import" function on the Profiles pane of the preferences. Remember though that Cura 14.07 is around 9 years old, so it is not so strange that support for it is fairly non-existent by now, and I don't think anyone has tested that import function with such old files for a good while now.
I was not able to make that work, probably for the reasons you stated. In the meantime, I've figured out that 14.07 is so simple I can jot down the settings for a particular .ini file on a sticky note and easily re-copy them into the current version.
Problem solved, as long as I hold on to my 14.07 version.
- 1
ahoeben 1,986
