On 2/12/2023 at 3:22 PM, TomEm said:
This are the given settings. When i change them to make the printer accurate, the problems started. The biggest problem is when i change to wall ordering “outside to inside”. At the start of the layer there is everytime a BLOB. Like it oozes out of the nozzle an then the printer moves(my oppinion).
GregValiant 980
@SteveVeritas - load a model and prepare Cura to slice, then use the "File | Save Project" command to create a 3mf file. Post the 3mf file here. It may be helpful if you posted the gcode file that you printed your example model with.
Someone will take a look. It's always hard to tell from images but with the data in hand maybe something will stick out.
TomEm 3
Hi @SteveVeritas
Look here:
Kind regards,
Tom
