Cura dropping LAN connction
adrianmudd
Go to solution Solved by gr5,
  • Solution
Posted · Cura dropping LAN connction
Do you have the latest firmware on your S3?  I believe some network improvements were included a year or two ago in the S3 firmware.
I believe, in the menu somewhere on the S3, there is an option for something like "digital factory reset" or "network reset".  Something like that (and they changed the name of the option a few years ago I think).  That resets a lot of things - not just the network connections.  This can often fix issues like this.
Also in cura you can manually tell Cura to search for and reconnect to your machine.
If you are using digital factory I don't think it does a local LAN connection but connects out on a server on the internet somewhere.
        • 28 replies
