Thank you for your quick response, below is the information.
Material: Fillamentum ABS Extrafil Grey
Printing Temperature: 250°C
Build plate temperature: 85°C
Infill: 100%
Resolution: 0,2 mm
Supports were used from ABS material.
Infill: 100%
Resolution: 0,2 mm
I would start off by trying a higher build plate temperature.
When I print with ABS I usually have the bed at 95-100°C, and I've noticed that it doesn't take much of a decrease in bed temp before the prints start to come off, at least from my experience. I do however print on glass bed with glue stick, but it might be worth a try in any case.
Ah, I checked the suggested settings for ABS Extrafil Grey, but the temperature range is quite big. I agree with @43915 that you probably need to increase the temperature.
If you intend to print with this material a lot it's good to figure out the correct buildplate temperature.
This is the test that we do to learn the buildplate temperature.
1. Print this file UMS7_buildplate_adhesion.3mf
2. Check the following things
3. Increase the builplate temperature in case it doesn't stick and is not flat, decrease it if the elephant foot is too big. You can also alter the initial layer speed between 10-30 mm/s if the temperature changes are not helping.
Good luck!
I used ABS from Ultimaker and raised the temperature on the build plate looks like it helped. Thank you for your help 🙂
MariMakes 168
Hey @Berec_admasys,
Welcome to the Ultimaker Community 🎉
Temperatures are super important for ABS so it might just be related to that. 🤔
Do you have for us:
A. The brand of ABS you are trying to print
B. Do you have a project file for us? It contains the printer and settings we need for troubleshooting. To save a project file go to File -> Save project.
