Actually, I'm back on 3.2.1 - recently upgraded from 14.07 🙂
I think I kinda sorta did what you suggested. Anyways, it worked. I opened my existing project file and cleared the platform. Contrary to what I thought I recalled, no warning dialog appeared. Then did "Save As" and saved as "new name.curaproject.3mf." Then I was able to import a new model and save model and profile as the new project file.
It looks like I can also clear the platform in a project file and bring in a new STL under the same project name. I encounter this frequently, since I often print a model and like the print result but find the model itself needs modification. Back to the CAD program to modify the drawing. New STL, import and print new version.
Appreciate the input.
DivingDuck 87
Add the new model to an open project first and then delete the old model. An other way is to save a developed profile as a new profile and attach it later to a new project.
BTW, actual version of Cura is 5.2.2.
