You should also have a solid brim in Cura.
Perhaps your bed is just slightly too far away from your nozzle.
Instead of squeezing the filament on the bed it is now more laying it on there.
I think this will create the gaps in your brim.
Line width and Slic3r reminds me of a http://www.extrudable.me/2013/11/03/slic3r-strange-defaults-causing-qu-bd-woes/. There he is writing about line width settings in Slic3r.
Maybe you found settings in Slic3r which give you a nice result with the original (0.65mm I think) line width settings? Taking all other settings such as e.g. a tweaked filament diameter to Cura which doesn't know a line width setting would then result in too thin lines.
It's just a rough theory... :wink:
Thanks for the help guys, much appreciated.
I thought about this some more this morning and recalled that I had seen these gappy brims when I was testing/analysing what was the best Z-offset distance for me. So I checked and saw that the start g-code I had used in Cura was very marginally different to what I had been using (the method of definition between the two is different).
So I changed the distance an reran and I am please to say it was successful
Well I say successful, one of the two pointy bits had a nice rhino horn and it is clear that a few layers from the end the nozzle tip caught on this. The piece was so well stuck to the bed that it did not move, but the glass bed did!!
Apart from that I am very pleased with the end result.
Daid 301
Never seen this problem happening on an Ultimaker. Maybe you're getting less extrusion then you are expecting?
As visible in the layer view, the brim is connected. (The layer-view parses the GCode and calculates extrusion widths from that)
