The fact that it prints well on one side of the bed but not the other makes me immediately assume that it's an issue with the bed leveling. I'm not sure how you level your bed and how you can be sure that it's perfect, but I've had this exact issue a couple of times and it's been because of bad bed leveling every single time.
I'm by no means an expert on 3D-printer software, but I can't imagine that the software would be causing the printer to underextrude on one specific side of the printer while extruding perfectly on another side. I'm not sure, but I've never heard of there being any settings related to extrusion rates that depend on the location of the printhead on the bed, which could potentially be acting up and causing this issue.
I'd say make absolutely sure that the bed is level, and that it's actually flat, and try again. I've had a bunch of different problems all caused by bad bed leveling, and it's such a sensitive factor that even the slightest deviation can give big issues depending on filament type and print job.
Edited by 43915
Schmordan 3
I've also tried checking the extruder gear and nozzle temperature, but nothing seems to work. Please help!
