Thanks for your reply! I can't print because no filament can be loaded. Actually, I can't perfom any action. This error pops up every time.
Do you think it is possible to block these notifications? If so, how? Do you have any experience with downgrading firmware?
gr5 2,192
I was just told that this is a new feature. It monitors the 24V power supply which is used by the steppers and heaters. It's possible that the limits for this error are set too sensitive but more likely I'd guess your power supply is somewhat defective and your steppers aren't getting the full power they deserve.
Since this is so new - just came out a few days ago - it's hard to judge which of these 2 things are truth.
Does it halt printing? maybe you can disable it in settings? I know very little about this. Does it let you print anyway?
