You can have Cura slice from the command line. Does that help? It's not trivial as there are many configuration files (machine config, profile, overrides, material config, per-nozzle config) but many people use this technique to automate slicing.
google "cura engine command line" and read both the github and forum articles.
MariMakes 208
Hey @Sven_Hinrichs,
Welcome to the Ultimaker Community 🎉
This looks like something that the ThingiBrowser does.
You can read more about it here: https://github.com/ChrisTerBeke/CuraThingiBrowserPlugin
It get's more trickier if you try to load a file format that is not supported
This is a list of supported file types https://support.makerbot.com/s/article/1667411286871
Can you help me understand, what problem are you trying to solve?
Sven_Hinrichs 0
Hi Mari,
Apologies, I didn't see your reply!
Essentially, I'm trying to automate a process where designs are stored centrally and I can "order" them from a central system. I want to avoid having to go into CURA and opening cad files individually (pull), but I'd rather have them pushed into CURA.
I have the following components:
Hope this makes sense?
