Thanks for the fast response and help! I apologize for the confusion. I mistakenly wrote motor mount. I meant one of the top 3 frame mounts for the 15 mm extrusion. I've uploaded an image of the layer output and an image of the layers up to the point of the problem. i have an arrow showing the location. I will post a pic of the actual print when I get home and add it to this post. it looks like it should print fine based on the layers. My printer is an ordbot hadron. I'm using wild bills PG35L extruder from thingverse: http://www.thingiverse.com/thing:24992%C2%A0%C2%A0
I usually save the gcode and import it into repeteir-host since I use repeteir firmware.
I will post my settings with the extra pic when I get them. Thanks again!
gr5 2,224
You mean this thing?
http://www.thingiverse.com/thing:167265
It slices fine for me if I put the skinny edge down (second to largest flat side). I didn't try putting the largest side down. Is that the right part even?
You have already activated your account so you can post images. On top right of this page click "Gallery", then click blue "upload" button. After uploading come back here and make a post and next to smiley face click "my media" and select "gallery images".
The problem is almost certainly visible in "layer view". Try it again and go through the layers and stop at the problem spot. The fix is most likely to uncheck "fix horrible" in expert settings. But I need more information to be sure.
What kind of printer do you have?
