yea... 120c is super cold.. if your printing pla at 120c, you have hardware issues on that machine... which you would need to reach out to the Creality community directly for help on.
for what I can see you have underextrusion raising the temperature usually helps i print my pla at 200°C
and a print speed of 70% how fast is 100%? try fiddling with the settings but even with bad pla a better printing quality should be doable.
GregValiant 1,364
I'm surprised it will extrude at all at 120°C. The default "Cold Extrusion Prevention" temperature (M302) should be about 170° in the firmware.
On 3/28/2023 at 4:59 PM, aabfm said:Quick question(s): are you using a nozzle temp of 120oC? Is this according to the recommended temp range of the filament you're using?
Guys I am very sorry. It is quick mistake in typing.
I printed at 220C.
Sorry for delay, not saw messages.
On 3/29/2023 at 11:54 AM, dsp said:for what I can see you have underextrusion raising the temperature usually helps i print my pla at 200°C
I printed always on 70% in Cura, and on printer is only 100% for default. That is,always work for me and not think that is problem there.
This week I returned to ABS (230/90C) and look how beutifull print is.
Edited by Smurf2
On 3/29/2023 at 3:40 PM, GregValiant said:I'm surprised it will extrude at all at 120°C. The default "Cold Extrusion Prevention" temperature (M302) should be about 170° in the firmware.
Sorry 😞 😞
Strange thing is what I notice is that sometimes is it hard, and then quick change to soft print.
You see on first black pictures on light, bottom is dark, and in middle start problem in current case (Post#1).
EDIT: This is today ABS print on 60%. It looks perfect print, but if you press it, you will hear a cracking. Maybe is that because thin walls.. Not sure that is been like that before.
Edited by Smurf2
aabfm 0
