The AA cores use "normal" brass (if there's such a thing). They will not wear much (if at all) if you only print PLA without abrasive additives. You should be fine, even after 5 years. You don't need a new printcore, unless your current one is giving you issues.
I see no reason to replace them for preventative maintenance. I just run them until they fail, usually because something in the hot end cracks or gets damaged from a filament flood or something, not very often.
ahoeben 1,963
Edited by ahoebenLink to post
