Probably not a setting but a rounding issue with a non-flat surface. You could try slightly adjusting the layer height, or the initial layer height. Better yet: make the model truely flat on top, not "approximately flat".
GregValiant 1,364
Good Morning
@UltimakerSV06 that looks a lot like what is going on in This Bug Report on Github. As @ahoeben mentioned it may be a rounding issue in the background calculations. This problem has also been mentioned here in the forum.
Thx for the reply.
maurice 1
I see now that the older version of Cura I use does the same thing. I also understand why it happens this way, but it is not always desirable...
