How do you actually load parts in the position they were saved?
Posted
· How do you actually load parts in the position they were saved?
STL objects will generally not maintain their relative positions. However, you can select multiple models loaded as separate STL files and "merge" them. This will first move them together, relative to their original position, and then group them. You can still select individual meshes in such a group (eg to set which extruder to print it with) by using ctrl+click.
Alternatively, you could try saving multiple models as one 3MF file. 3MF files normally do keep their original location.
Posted
Thanks for sharing the trick. It does look like merge brings them to their saved position (also retaining the different material assignments), and now I can also re-orient them together.
This should work!
ahoeben 1,800
