How to engrave less outlines on bottom and top layers
Posted
· How to engrave less outlines on bottom and top layers
Yes, do just what you propose. Although you can create a support blocker you are switching that to a mesh modifier. But I know what you mean.
Be warned that there will be 3 wall lines from the outer part and one wall line at the inner part where the mesh modifier is so use that as a way to outline the embossed letters.
Another trick might be to use a feature called "ironing" which can, I think, hide those walls. Maybe play with that as well.
gr5 2,224
