- Solution
Hello @Dustin and everyone!
I finally found some time to do some more tests regarding this issue. It turns out that the problem was with the project files themselves, and NOT with Cura 5.3.1. For some odd reason, some of the parameters I had changed in Cura 4 were flagged as "not changed" in the project file, and Cura 5.3.1 simply didn't update them when the project file was loaded. I don't know what caused the project files to behave like this, perhaps a bug in an older version of Cura 4 I was using at the time.
I have now updated all my Cura project files, and they all load correctly in Cura 5.3.1.
In conclusion, there is no need to do anything in Cura 5.3.1. I have already closed the issue I raised about this in GitHub.
Many thanks to @MariMakes for taking the time to respond on GitHub, and please accept my apologies for raising an issue which was not what I initially thought it was... I'm happy that my confidence in Cura 5.3.1 has been restored and that my project files are now loading correctly.
1
Dustin 193
Sorry your having issues, however the best place to report bugs and issues is over on github.
Reporting the issue to github ensures the dev team actually sees the report.
You can report the issue here: https://github.com/Ultimaker/Cura/issues
DrCeeVee 19
Hi @Dustin, many thanks for pointing me to GitHub. I've just raised an issue about this there. Hopefully, the developers will see it and do something about it.
This is a serious issue for us, because we have many project files created in Cura 4, which have been perfectly fine-tuned to print specific parts. Not having the confidence that all project settings are imported every time we open a project file defies the purpose of using project files, and forces us to manually check and add the missing parameters. This is time-consuming and prone to errors. I hope this issue will be resolved soon.
