All walls begin at the white points shown in both cura versions. With the same settings I get good startings in old version but bad startings (I call it seam) in the new version. some startings on no sharp corner in the wall in the new version. Strange.
DivingDuck 105
This is why I set it the most time to my own preference ("User Specified"). Gives me mostly less hassle between versions and mostly better and repeatable results (at least felt like).
Torgeir 289
Hi @moschidreamer,
As far as I'll know, this is not a "seam" line, but a "start" line.
The "seam" line is a line where the height are adjusted and there is no color showing this in Cura.
The "start" line can even be inside the object, but Cura will still show it (can be turned off).
However, in the first picture, the marking in the right corner is something, -but impossible to see well.
Never used Prusa slicer.
Thanks
Torgeir
