Hello @EPALMI! I am facing similar problems with my model! I changed speed, layer thickness and others but to no success! Everytime I try to print, the PVA supports go all over the place. Have you solved the issue?
Thank you :)
1
Enigma_M4 101
If you don't have the prime tower activated, you could give it a try. It's meant exactly for this purpose.
On the other hand, if only the support structure is affected, you just could leave it at it is and live with it...
Regards
EPALMI 2
Thanks for your reply Enigma_M4, I'm still looking for some other solutions in the line of reducing the speed of the tower when switching between extruders.
Thank you anyway.
E.
