An easier to read version is available here:
http://files.fieldofview.com/cura/Replacement_Patterns.html
While @nallath is right that you can use functions (and math) for setting values in profiles, you cannot do so in start- and end-gcode snippets.
2
nallath 1,117
The whole list is here: https://github.com/Ultimaker/Cura/blob/main/resources/definitions/fdmprinter.def.json
You can also use functions in the value, which is done in quite a few places
