It seems the first 3 settings in cura you should probably look at and play with are:
infill density
wall thickness
top/bottom thickness (aka skin)
You can experiment with different values for "infill density". And if you want to measure purely just the infill you can set wall thickness and top/bottom thickness to zero so you get *only* infill.
gr5 2,069
1) Do you already own an S3 or are you just looking at the spcs?
2) Can you explain why you want to change line width with speed (I'm not judging - I just need to understand your goals)?
I'm not sure if this is more a question about Cura settings or more about hardware.
gonzalozar 0
Thank for the fast reply @gr5!!,
1) I do not personally own one, but I work in a place that have them, and we are carrying out some projects as research & development of new types of "3D printing approaches".
2) I want to print 3D bodies with different densities specific areas or layers, to later test them and learn how they behave in different conditions of mechanical stress. I'm just in the planning phase, but I think having those parameters would help me understand the printer capabilities better and thus achieve the goal.
