The version of Cura which comes on memory card with Elegoo Neptune 3 plus is definately designated 4.8.0 but that is reall of no interest since I followed the upgrade to 5.3.1.
.3mf file attached thanks regards Dave
The nozzle for the printer is listed as a 0.4 and here are the line widths from your setup.
In addition, you have the Minimum Line Width at 0.34 which is a contradiction since you are asking for .2 (and a .1) line width.
I don't know what you are using for a build plate, but this piece should absolutely not need a raft. It has good surface contact and should stick.
At any rate, I made some changes and here it is back at you.
I'm going to guess it's the front wall of a steam locomotive cab?
GregValiant 1,115
It's likely in your settings (there are a lot of settings). Load the model, set Cura up to slice, use the "File | Save Project" command and post that 3mf file here.
Look at "Wall Order" in 5.3.1. There was no such thing in 4.8 and many printers struggle when the wall order is "Outside to Inside".
Those travel lines look like extrusions rather than strings. Make sure "Spiralize" is turned off.
