So it looks like the biggest issue was mechanical in nature.
I think I had a wheel or two a bit to tight. However I am left with one issue and I am convinced it's Slicer related.
If you see the hole at the top of the top of the lower hole there is a line that is showing up where the holes stop and start.
Not sure what causes that.
Torgeir 228
Hi @rickyg32,
This might happen with the kind of "special" models we try to print, this as the slicer "cannot" fill the holes that's appear at every crossing lines/cut on the model.
We may have a more correct "assuming" if you share your model in here as a project file.
If this is the problem, you may try to adjust the layer height and there will be an improvement on this issue.
Thanks
Torgeir.
