@ Ulitmaker Support Team
I am digging out that topic which hasn't been answered by the community as I have again the issue with different projects with Cura 5.4
I would emphasis on the fact that the meshes don't have any reported issues from Cura or Fusion360 or Meshmixer.
Fixing them (wrapping or rebuilding) does not change any of the results below.
Here's the first project file.
Sliced with Cura 5.4, there are some tool path issues (same issue on each part)
Same project sliced with Cura 5.3.1, no issues at all.
Here's the second project file
EW50_2-25x-deksel-original.3mf
The tool path issues with Cura 5.4
And the correct slicing with Cura 5.3.1 ....
This issue is critical as Cura 5.4 can no longer be trusted with some basic issues, though tree supports are a major advantage.
Can you please have an urgent look at this issue ?
Edited by V3DPrinting
V3DPrinting 11
Hi again
I have also some slicing errors on another model. Mesh is also fine (STL has been created from Fusion 360 / Solid modeling and then rebuilt with Meshmixer to be sure there is no errors).
The model is a continuous extrusion of a profile in these areas, so it shouldn't have any shifting.
There is some sort of layer shifting, but in Cura. It happens with Cura 5.3 and 5.4.
Here's the project file
EW50_Support_Tablette_10_in_V3_Fixed.3mf
Thanks for your help
Best
