Ik heb cura versie 5.3.1. weer geinstalleerd. Die gebruikte ik voorheen. Nu geen problemen!
GregValiant 1,304
Load a Benchy or calibration cube into Cura 5.4.0 and use the "File | Save Project" command. Post the 3mf file here.
There should be no difference from 5.3.1 to 5.4.0 regarding extrusions unless your printer definition file was changed.
GregValiant 1,304
All of a sudden I had the problem with every version of Cura, every version of PrusaSlicer, every version of IdeaMaker...every version of all of them. About 30 to 45 minutes in to any print and the extruder would start skipping.
My problem was two problems that were stacked on top of each other. The stock Creality hot end of my 3 Pro AND a bad stepper driver on the 1.1.5 mainboard I had put in. Having both go at the same time was really hard to troubleshoot. Fortunately I had the stock mainboard sitting around. When I put it back in everything became clear.
