Posted
· Ultimaker S5 takes 18 minutes to start print
It might be normal, yes.
So before it prints it has to do active leveling and for that it can't have solid filament on the nozzle so it heats the bed and the nozzle to prevent any filament from throwing off the leveling adjustment - even 0.1mm of error would be bad.
So look in cura at the bed temp as the bed takes the longest to heat up. If you are printing say ABS then you probably want around 110C bed temp and that can indeed take 15 minutes when you include heating up the nozzles also. But if you are printing PLA than it should only take, I'd guess, 5 minutes before it starts leveling.
As far as 15 minutes to abort, that can be avoided. For safety reasons (which I disagree with), it waits for the bed to get below the safety temp before allowing you to print again. I hate this feature. You can disable it with this tool (ultituner):
I remember putting a towel on the bed after an abort so I could keep the bed hot to quickly restart the print. Well this slowed down things even more! I was quite mad. It was not obvious that it was trying to cool down.
Also you can go into the second menu on the left and click on bed and in top right click "..." and then something like "set bed temp" and then you can see the current temp of the heated bed and if it is going up or down (which provides hints). Similary you can check the temps of the nozzles.
After a print there is also a short delay (maybe 20 seconds) to do a semi-cold pull to avoid tiny strings in the bowden jamming the filament which is a very good feature. But waiting for the bed to cool? No way. Absolutely hate that feature with a passion.
gr5 2,243
https://community.ultimaker.com/topic/39188-ultituner-a-tool-to-tweak-your-printer/
Mesk73 0
Thank you, that helps clear things up. At least I'm not the only one suffering with the setup times.
