Hi Greg,
Thanks for your answer.
So the last thing I changed was the extruder.
I switched to direct drive.
I moved the extruder along X axis and realized that it wasn't moving evenly. It felt like it was falling into a notch every coulple inches.
I replaced the wheels and it is now moving smoothly. I reckon some wheel shape irregularity was causing the nozzle to move wobble vertically while the extruder was moving along the X axis.
I have also reduced the inner wall flow. The quality has has improved a lot. But the uneven extrusion along X axis is still there, but has improved a lot.
I will try and verify if the bed is heated evenly.
Should I upgrade the x axis to a rail and get rid of the wheels?
GregValiant 1,489
Looking at the areas of skin that show the problem, the X axis areas just outboard don't look so good either.
Hot end is tight?
Bed is heating evenly?
If you have a decent magnifying glass take a look at the individual extrusions. I'm far away but the ones that are split apart look pretty round (not squished) while the ones that appear welded together seem to be flat like they should be.
What is the last thing you changed on the printer? Check it over again.
