Posted · Custom Gcode for Ultimaker 2+
I'm new to 3d printing with Ultimaker. I'm looking to add a custom gcode for my prints. I'm trying to make the printer stop for 10 seconds after every layer so that I can take a picture. Is it possible to do it via Ultimaker Cura?
I see that this might be possible in PrusaSlicer
    If you are referring to the UltiMaker 2+ Connect
    The answer would be no. The firmware does not support these pause commands from any slicer.
    AFAIK, hidden inside each UM printer is a fork of a rather old version of Marlin. However the modern ones (Ultimaker 3 and newer, including the Ultimaker 2+ Connect) have a proprietary linux-based firmware shell around that Marlin-based controller.
    • Like 2
    5 hours ago, KhanS said:
    Which firmware are the Ultimaker printers running? I couldn't find this information. Is it Klipper?
    No it is not Klipper the S series run a customized (older) version of Marlin which is referred to as Griffin
    This is not based on Klipper, its custom as there is a pre-processing module in the printer itself that intercepts the gcode and processes it prior to being handed off to the motion controller
    Yes you can pause the print (S series only, this does not apply to 2+Connect) with the post processing plugin in UltiMaker Cura, ensure "Method" is set to Griffin.
    The 2+Connect uses a version of firmware similar to the S series but is very slimmed down due to the considerably reduced specifications of the hardware in the pre-processor
