Hi @Turtlestein,
Welcome in here.
The hat is not joined to the I and it is also leaky (not watertight).
Your project can only be opened as a project, I.E with your printer.
But if you select "surface mode" it will be opened with other printers!
If you use Cura 14.13.1 and make some more selections in the "Mesh Settings" as here, you will see the most of your hat.
The "funny" thing is that, at some other settings you can see the missing part of your hat but not this part grayed out.
Thanks
Torgeir
Slashee_the_Cow 347
It's hard to tell without the individual models, but the hat looks hollow. Cura is not a huge fan of that. If I go to Mesh Fixes > Remove All Holes, it closes the hat up at the bottom and prints the cone part, but not the brim. Try adding some poly/s that go around the circumference of the brim to close up the inside of the model entirely.
